100% used motor oil fuel.
tsmall07
Springfield, VA
I just found a pump that I can afford. Do you guys think this pump will work ok to pump through 2 filters? I don't care if it takes a while. I was going to use a 10 micron and then a 5 micron filter/water separator. I don't know what pressure/flow rate to use for a pump.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
No, get a barrel pump. The pressures you will find are much higher. The filters I use is a set of secondary and final off the side of a deuce motor. Even new I see pressures as high as 25psi. Once they get dirty, it gets up to 100psi real quick. None of my filters are 5 micron, you will see higher pressures.
avengeusa
MI USA
so where does one get a barrel pump?
and are you preheating your oil before pumping?
randyscycle
Rhoadesville VA (where!)
At 1 GPM, you're going to be there a while too. That pump is for spraying duties. Generally they won't pump very well with higher viscosity fluids like oil. They also usually aren't self-priming, which means they won't pick oil up a long pickup tube in say a barrel or tank. Most spray rigs have the pump mounted lower than the tank so gravity does most of the work.
gimpyrobb
27,786
755
Cincy Ohio
No I am not heating my oil. Horrible freight is where alot of members have got theirs from, but they consume lots of air. I got mine from GL, $60 for 2. I had to replace the seals in the one I am using($18), but it is awesome and the deuce air supply can keep up with it. I missed the 1gal per hour part, that pump is worthless for WMO.
avengeusa
MI USA
aha, so it is an air powered pump......
I am near one, a horrible freight, i was going to use a dual remote filter setup for the filtering, i was thinking something like this below
AutoZone.com | Vehicle Selection | Year
I am going to call purolator and see which gm type filters that i can get to filter the oil which do not have a bypass on them.....
and what micron ratings i can get out of them
I have a lot of oil and trans fluid around here, at least 600 gallons
avengeusa
MI USA
The rotor is about 3" deep also it looks like a bowl with a 1 1/2" lip at the top. Google Simple centrifuge for picts.
bought 6061 aluminum, cut to size, and am making a batch of centrifuge bowls
a couple standard 8 inchers, and a couple 9 inchers.....
I will post pics, bought the motors, found them cheap, new
so i am in the centrifuge buisness
stampy
22
Henderson. NC
Great! Hey when you get your bowls done pm me with a price I have a buddy who wants one but doesn't want to pay simple centrifuges price.:-D
Ferroequinologist
Resident railroad expert
742
Liberty Hill, SC
Years ago I had the Opportunity to purchase a sharples lube oil purifier off GL. http://www.ussslater.org/decks/platfrm2/purifier.html
We used one just like it on our ship for our main reduction gear lube oil and controllable pitch propeller systems. Not sure what the GPM was, but it would do a 1800gal sump in like 14hrs, and that's recirculating it.
I keep kicking myself for not buying it.
I need to build a WMO set up now, as I can get lots of it here from the locomotives and such.
avengeusa
MI USA
Years ago I had the Opportunity to purchase a sharples lube oil purifier off GL. USS Slater, Windlass Room
you are golden if you have access to wmo from railroad trains
definitely build one
I have a lot of atf, and wmo available also, that is why i am building
Ferroequinologist
742
Liberty Hill, SC
Yep, these locomotives are only 11 gallons in each engine (two cummins NTA-855 engines per locomotive, so only 22gal each time on these) but the other ones I work on are 250+ in the sump. That will keep me on the road a good long while! :-D
Anyone have problems with storing used motor oil in poly drums or totes?
gimpyrobb
27,786
755
Cincy Ohio
Nope, I have been using 55gal poly tanks for 2 years w/o problems. I have the metal 250gal hho tanks for bulk storage too.
Ferroequinologist
742
Liberty Hill, SC
Thanks Gimpy! Good to know. I have a 250gal HHO tank as well, was looking into getting another one and mounting them on a M105 trailer frame. Voila! homemade buffalo.
gimpyrobb
27,786
755
Cincy Ohio
The only problem I have is when I used the 250gal tank for this last trip, I used a hose hooked to the bottom of the tank to gravity fill my truck's tank. It was PAINFULLY slow. I suppose some iron pipe, instead of the garden hose I used would work better, but I digress.
liquidferrum
Oshkosh WI
i have an IDI ford f250 and it will eat anything. i feed it wmo,(umo) wvo, paint thinner, some gasoline in the mix. i have ran it on 100% umo and wvo. i filter it to 5 micron, because the fuel filter on it (10 micron) is a nominal rated filter, not absolute. that means that the AVERAGE particulate size is 10 micron. so it never hurts to over filter. umo tends to have less water in it also. and i read somewhere that it has more BTU/gal than diesel.
just get it out of there before the temps drop.. i start to struggle with 100% below 70 degrees F
centrifuge is the way to go!!
