Fleet angle vs level wind
cranetruck
94
Meadows of Dan, Virginia
Some of my questions may be obvious to the experienced winch operator, but I'm only trying get a little educated before messing with the 8x8 winch. Most likely, I'll be working it alone, so...
The way I understand it is that the great majority of front mounted winches do not have a level wind, but must rely on tension and proper angle for a tightly wound drum.
Question 1: How critical is this "fleet angle"?
Question 2: Is the "level wind" device and "tensioner" really needed if there is tension on the cable and the fleet angle within the 2° as shown in the FM-20-22?
Question 3: According to the manuals, the only winch operator anywhere near the winch during the actual winching op is the person in the driver's seat, so do you just "go for it" once winching starts and hope that the cable ends up nice an tight on the drum or do you stop and check how it goes every so often? Again, how critical is the fleet angle?
Thanks
rizzo
9
Port Huron, MI
most of the time you have to work with what you have. I either get out and check the windings or I have someone watch it. all my pulls I have never had a problem or had to stop and unwind. but I was lucky enough to be able to pull straight. If I can control the angle I always set it up as close to 0 as possible.
jwaller
20
Columbia, SC
on my deuce I use the winch to get me out of where I'm at and once back home I will pull the cable and wind it properly. there is almost no way to always keep a 2deg angle on every pull.
cranetruck
94
Thanks for responding! I checked the FMTV winch set-up and it gets a straight pull 100% of the time via guide rollers along the frame and no level winder is needed (as far as I can determine any way).
rosco
32
Delta Junction, Alaska
Important about all winching - especially alone.... Make sure you are out of gear/winch stopped, before you get out of the truck to inspect! If you have help, make sure you can see your helper - always!
I have never had a Level-Wind. That sounds really neat & handy. Otherwise its important to keep the line straight on, in you pulls, and always have tension. I will stop winching often, to check the progress. You will find, that if your line has been used much, it might not wind even, even if you are dead on with a straight pull. Snatch blocks are a super tool. They are like vise grips - the only thing better then one, is to have several. They should always stay with the vehicle - when you need them, they are no good to you , when they are back in the shed.
I have turned around on a narrow, one lane road, on a steep side hill, by stripping off a lot of line, then re-winding it on the Hi side of the drum, so when the pulling at a sharp angle, the line winds on the low side of the drum - thereby dragging the front end around. But you may only get a few turns of the drum, before you have to re-strip the line, and rewind it. It can be a whole lot of work.
Most winching, I have found, requires a whole lot of improvisation. Nothing is perfect, and your lucky to even have a tree, much less, a tree in the right place, to winch from.
Lee in Alaska
BFR
Rocket Surgeon
2,330
42
North Georgia
agreed
I found that pulling something small up a slight slope works well when re-spooling after the fact. (I used a toyota pick up)
NDT
7,520
Camp Wood/LC, TX
Has anyone found a safe way of neatly rewinding the cable after a pull? My method involves engaging the winch, running out of the cab and grabbing the cable with leather gloves, and guideing it onto the drum. The extra dangerous part is the last few feet when I have to jump in the cab and disengage the winch before the end of the cable gets sucked into the winch under the top plate. I can't get the disengage lever to move when the winch is tugging under light load. On my M135 it is no problem, I just attach a string to the throttle lever and give a little pull to speed up the engine and cause the auto trans to drive the winch.
LanceRobson
220
Pinnacle, Stokes County, NC
1. The fleet angle becomes more critical at higher loads. A low angle will allow the cable to bear on the side of the previous wrap and lay neatly into the valley of the two wraps underneath it.
A wide angle will cause the cable to lay over a previous wrap or wander way from the previous wraps which will eventually lead to the same thing. When the cable lays over another wrap, the lower cable, in effect, acts like the sheave in a pulley or a roller and places a terrific load on the point of contact flattening out the cable and causing a kink.
Picture the stress on the cable if it was using a 1/2" diameter pulley and that's where the problem comes from. It takes very little line tension to kink the line under these conditions. Any kinking must then be cut out etc.
Note that allowing the cable to bear on the upper edge of the bumper has the effect of running it over a pully the radius of the bumper's edge. It can ruin a heavily loaded cable in a second.
2. Tensioners and level winds are not "really needed" They are on wreckers because they'll use the winch more in 6 months than most operators would in 10 years and they're a lot more likely to heavily load the winch. That said, if I ever find a set at a price I can afford, I'll be on them like a bad rash.
3. How close I am willing to be to the loaded cable is a function of how much load is on the cable and how much faith I have in the person in the cab. Jerky clutch operation is a lot more likely to break things (hopefully starting with the shear pin) than a smooth slow clutch release.
If you are by yourself I'd suggest pulling in only a few wraps before dismounting to check and be very conservative until you get a feel for what is happening.
Make sure the band brake and drum friction brake are properly adjusted. If they are not correct, you'll be a lot more likely to have problems.
While you need to pay attention to the item you are pulling, try to keep some attention on the line close to the vehicle. You can see a little jump in the cable when it hops up onto a previous wrap or starts a new layer.
The fleet angle IS critical. The higher the fleet angle, the more stress is put on the bearings and housings of the winch. The bearings and housings are very easy to damage at high fleet angles. The result of higher fleet angles is to dramatically reduce the winch's rated capacity.
Sometimes high angles are tough to avoid but I'd rather use 2 or 3 blocks to avoid them.
Lance
Recovry4x4
LLM/Member 785
1,827
GA Mountains
I have been meaning to build a magnet mount mirror for this task but haven't yet. Also, don't forget your ears. You can identify alot of problems stewing if you just kisted to what you are doing.
cranetruck
94
1. The fleet angle becomes more critical at higher loads. A low angle will allow the cable to bear on the side of the previous wrap and lay neatly into the valley of the two wraps underneath it........snip snip
Lance
This leads to proper lubrication as I see it, how do you guys handle that little detail?
73m819
329
gainesville, ga.
as far as lube goes I use a spray chain and cable lube made by lubaiplate
as far as the fleet angle goes if you just use a level wind without the tensioner on the 5t the cable will bunch up on the pulled side if the fleet angle is off a all
Squirt-Truck
Master Chief
164
Marietta, Georgia
The Lubriplate that Ron is refering to is great for the rope. I am still using that materal since he gave me a can in Kennesaw 3 years ago.
Level winds are great, but useless without the tensioner. However,with the tensioner the fleet angle opens up to about 20 degrees, limited only by the clearance opening of the front bumper.
You cannot over lube the rope, just how much mess do you want to make?
But, if you are running the fiber core rope, and not IWRC then you MUST use water displacing lube, or the corrosion from the inside will kill the rope. Just like overload did this one......
LanceRobson
220
I use "exposed cable and gear" lube. I've got a couple of makers stuff in the shop. I'll get the maker's names off the can tomorrow.
The fleet angle, when using a tensioner, is really restrained by the rollers acting as sheaves when under load. Since they are smaller than the appropriate sheave you can't pull as hard over them or the cable will be damaged. Sideways loads on the rollers and their bearings are an issue, too, hence the 20 degree limit.
Lance
Jake0147
Panton, VT
Very critical, depending on which way the angle is and which way the particular layer is winding. If you're pulling towards the newer layer, much more of an angle is possible. Not exceptionally good for the cable, but if the cable is in fair to good condition and lubed at all (even if less than ideal) then you have some flexibility there. It's not good for it, but it's a lot less damaging than a lot of other things that invariably will happen to a winch cable used in this sort of application. If you're pulling away from the newest and highest layer, two degrees is great for brand spankin' new cable, but once it's settled in and trained the "grooves" between each wrap in the lower layer become less pronounced and don't trap the next layer as well, so that two degrees becomes reduced.
Example- At work, the light duty conventional wreckers, pulling in at approximately 3000 pounds (winch not straining, but cable at a full load) as the cable comes over the sheave, and onto the drum, it's lined up for the center of the drum. As the first half of a layer winds up (assuming there is a lower layer under it) that one degree is too much angle in the wrong direction, it doesn't stay tight. New cables will, old (but legally, technically and safely servicable) cables will not stay tight. They only needs a light "guide" with simple palm pressure against it to keep it tight even under that load, but once the new is gone it will not do it by it's self.The second half of every layer always stays tight by it's self.
I have not had the privledge of seeing a military level winder. I have used ones on our light tow trucks. If they are matched, factory options or factory retrofits, they are priceless. If they are universal, mismatched, or otherwise not perfect in every way, then not necessarily so. While the mechanics of them may be very simple, their job is quite simple. Seeing how these military ones are "supposed" to go with the winches to which they are installed, I can not see any way in which they could fail to operate correctly.
Unlike the civvy stuff I have played with, the military ones (I believe) are not tensioners, so while angle is not so much an issue, you are still not relieved of keeping tension on the cable while winding it in to keep all the wraps tight.
... Also, don't forget your ears....
I am wondering abut this myself. My winch isn't on yet, I know on civvy stuff (where you can hear yourself think when the engine is off idle) that you can hear and feel something not right with your winch and/or cable system very reliably. How much can you hear and/or feel from the deuce's driver's seat? Can you feel a cable that's rubbing something, even if it's around a corner or over an embankment, or are you relying solely on the spotter? Can you hear how much load on a cable when you've miscalculated a pull?
Has anyone found a safe way of neatly rewinding the cable after a pull?.
At work we find it's much much faster and easier to take the other approach, fix the anchor and "reel in" the tow truck up a small incline. It's heavier, that way you don't need a "big incline" which we don't have. On the wreckers it doesn't matter so much, but on the flatbets, (and I'm sure on the front winch of a deuce) you can turn the steering wheel just a touch to keep the cable always pulling just the slightest touch into the last wrap. If an operator is skilled, it is an operation that I will allow them to do themselves. New guys have to keep a skilled operator handy just in case, until they themselves demonstrate a good proficiency.
In the case of a Deuce, the winch controls are inside the cab, so a spotter would bein order, or several "stop and checks" along the way, but it would keep your hands off of the cable and keep the winch out of "auto pilot mode", both of which I would be POSSIBLY considered necessary evils, but both are definately better avoided.
New engine oil. If it's tightly wrapped, with a little practice you can pretty much gauge by how dry it looks just how much oil you can put on them. It stays OK, not as well as properl cable lube, but it's one less thing to keep around. Cable lube is tacky and gets on everything after bit. It also catches more dirt if the cable is on the ground for any reason. Engine oil is much easier to wash off of steering wheels, seats, door latches, etc. and doesn't hold dirt so much. In our business it's an easy call, since some of those dirty items may be on a customer's car. And dirt on the cable of course is abrasive, and just not a good thing at all. On a MV where the use will be minimal... How clean can you keep yourself? Can you always guarantee enough pairs of gloves to be around that you don't track cable lube all over your tool box and everything in it? Can you keep the cable off of the ground? That's the benefit and the drawback of cable lube over other lubes. It is sticky.
rizzo
9
Port Huron, MI
I bought a magnet block from HF for this, but have yet to mound a mirror to it
tm america
25
merrillville in
i was thinking about making a removable mirror mount to go off the grill so i could watch the cable as its winding on the drum when im by myself i dont like having anyone near the cable either way id rather have a messed up cable than a dead friend :roll:but you have to make sure to only pull out as much cable as needed seem the way it starts is the way its gonna wind .ive winched off of trees that were pretty far off to the side its ok as long as you dont wind to kuch on one side cuz the cable could try to fall off the side of the drum then you have real problems .i hook to a tree ride the brake and winch in. when i stop to check how things are winding i always shut the engine off for safety sake
timntrucks
146
Ponchatoula LA
yes everyone chimmed in with some good advice..... always go slow and take super extra care and checked it all twice. or three times to be sure . its not like your going anywhere fast if your stuck right Tim :-D
jesusgatos
on the road - in CA right now
Is there a level-winder/tensioner for the deuce winches? If not, what about adapting one from another application? I'm just trying to figure out what kind of winch I'm going to get for Mah Deuce and how/where I'm going to mount it.
