need pic of multifuel cab heater
jwaller
19
Columbia, SC
I am finishing up the install of my multifuel cab heater and I dont have any really good pics of the exhaust pipe routing. if anybody has some I'm in the need of them please post them up. also any pics of the fuel supply line and it's mounting points as it moves from the pump to the heater would be very helpful.
jwaller
19
Columbia, SC
this might help
if you have the oil pan shroud it would exhaust in to that
Harry
not quite. there are actually 2 heaters in the full on artic kit. the one for the engine routes to the oil pan shroud and the one for the cab dumps out behind the LF tire. right now I need the one for the cab heat.
I have been using that pic but it doesn't show how the exhaust is routed.
dm22630
42
Front Royal, VA 22630
I literally just took mine OFF yesterday....
The exhaust pipe is held on by 3 clamps.
#1 - inside the fender next to the firewall (small opening) that is basically 5 inches away from the clutch on the engine side.
#2 - 2nd bolt from bottom that holds the fender on.
#3 - bottom bolt that holds the fender on.
I can take pics in the AM if you arent sure what I mean.
It took 15 minutes to remove.
