kiotiugly
- 0
- 1
- Western Kentucky
On my new-to-me M35, it seems as though I have one rear brake shoe sticking (maybe).
The symptoms consist of one brake drum that is about 400 degrees, while the other 3 rear drums are all about 70 to 90 degrees. There's also a smell of something burning (brake shoe material might be my guess).
I've looked at the TMs, although not as thoroughly as I will in the next few days. I thought that I might get some advice from you guys that have worked on your brakes before. Any idea what might be the most likely culprit as to why the brakes aren't releasing? I'm not familiar with an air/hydraulic braking system (I've only had the truck 4 days so far). I am fairly familiar with regular drum brakes, and the diagrams for the TM look pretty similar.
Also, is there any trick to getting the drum off? I know on some of my old trucks you can manually pull the shoes in and (sometimes) the drum comes off fairly easily.
Thanks in advance for the help. Take care.
