Deuce PArking Brake
MDSA
12
Valdese, NC
Finally got around to adjusting the parking brake on my Deuce. I was having trouble with the cable as well. It wouldn't move. I was looking at it the other day and I found a grease fitting on the cable under the cab that I had been told about but had never seen. So... no grease in quite some time. A few squirts of grease and the cable now moves.
I had heard adjusting the parking brake could be a pain, and it was very awkward getting to it and keeping wrenches on it, but it is so nice having a nice tight parking brake again.
ecostruction
York, PA
I consider the handle a way to fine tune the brake. To adjust outside the range of the handle, you need to find the lever on the drum under the truck. Might be able to see it between cab and cargo bed, but to adjust, you need to sit under the truck.
KaiserPower
Pottsville, PA
While your under there, check the return spring above the brake shoes, at the end of the cable... It's attached to a small metal tab... I just replaced my shoes and saw that the spring had cut a 3/4" groove across that tab and was about to become unsecured. I had to drill a new hole to hook the spring to before it failed. You'll need at least a foot long drill bit to reach up in there over everything to do it.
Boatcarpenter
17
Marlborough, NH
Don't forget to make sure the "U" or horseshoe spring is there on the bottom of the shoes also or the rattle at certain speeds will drive you crazy trying to find. it.
BC
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
John, I think the cables w/o the grease zerk is for the adjustable handle and the ones with are for the whale tail style. I have never seen them any other way. .02
dittle
72
Albia, IA
If the nut on the end of the cable (assuming its same on old style cable as new) has moved once keep an eye on it as it may move again. Simple fix is just to put a second nut against the first one to keep them from moving. The one on my deuce loosened itself after I had adjusted it so I just double nutted it....problem solved.
otisroy
Melbourne, FL
Do you remember what size the nut was? I think mine came loose this weekend, but I didn't have time to mess with it since it was Mother's Day and all.
dittle
72
Albia, IA
I don't remember the size of the nut, I have access to the original hardware at the museum so I just used a 2nd one of those. I can look Wed/Thurs this week as I'll be at the museum moving some tanks around.
k4vem4n
Fort Lauderdale, Fl
I am having the same problem....I pumped the fitting FULL of grease until it started oozing out near the brake handle....still STUCK....I'm afraid the grease traveled up to the handle only and the part that is "seized" is more towards the drum.
If I could just get it to break free....shoulda seen me I musta looked like dang monkey jumping up and down tryin with all my strength.
I haven't been able to find another grease fitting.... anyone have a suggestion short of replacing the cable? The cable is fine...no rust, frays, cuts..(that I can see).
I'm thinking I may have to remove the entire cable to straighten it out and force it to move. what a PITA!
k4vem4n
Fort Lauderdale, Fl
With a torch? Should I heat the cable directly? near the arm at the hub?
I picture the the grease liquefying and flowing down to the....by god it just might work!!!
Thanks, sounds like a good idea, I'll give it a shot later.
k4vem4n
Fort Lauderdale, Fl
Well back to square one....
I heated up both ends of the cable with a torch and tugged on the lever....repeatedly. probably did this at least ten times.
I felt like the lever was going to give in before the cable would budge, (the lever started twisting)
I think, if anything, I'll need to pull the cable from the hub end, just to break it free.
So, I'll give it another shot tomorrow. I'll have to disconnect the cable so it hangs, so I can grab a hold of the end, since there is no place to get leverage to pull the arm......hmmm, maybe i'll whack the arm with a mallet......there might be room for that... we'll see
gimpyrobb
27,785
749
Cincy Ohio
I meant heat the cable in the middle, not the ends. Another way is to release the bake handle and to pull the outside shoe toward the passenger side of the truck. When driving trucks from Tx to Wi for Westy, we had a parking brake freeze on us in the "on" position. We ended up using a come-a-long to winch the arm open. It moved before, so we knew it would move again.
k4vem4n
Fort Lauderdale, Fl
If I heat it in the middle, I would melt the plastic sleeve. or did you mean by heating it, just to "warm" it up a little with indirect heat?
I think I'll try to hook a come-a-long to the arm too. Force that cable through... that thing is REALLY stuck in there.
