Dan6wd
- 0
- 6
- morehead city nc
Hello guys, it appears as though I have been driving for A few months with as crack in the inlet of my fdc. I realised it when it got so bad that diesel was spraying all over everywhere! does anyone have, or know where I can get a new fdc? My truck had just been decomissioned from the military when i accuired it, also it came with an military work order that showed 10,000 worth of replacement parts, the injector pump was one of them. Apparently the tech overtightened the fuel pipe fitting and slightly cracked the housing, which I just found out is made of aluminum! I understand the fdc bypass, however if I rerouth the return line as the diagram shows I will have fuel coming back out of the damaged fdc inlet hole. I have seen in an earlier thread where someone had A simple metal plate where the fdc would normally be. I wonder where the small fuel return line, from the injectors would route to? The only numbers on the fdc are, bendix zenith 10951200
