Parts for deuce
IMA944T
OKLAHOMA CITY
Looking for the fexiable fuel hose from primary filter on the right frt to the injector pump. Has small leak and would like to replace it. Wondering if it available or should I remove and have one built. Whats the good way to keep the fuel from drain from IP when it's removed before reinstalling it.
Also need a new speedo adapter. It has 11 x 20 tires and have noticed some adaptors are reverse and std.????
IMA944T
OKLAHOMA CITY
Will this do for the tire size and make speedo correct? The five ton has 14x20 on it stock but the speedo adaptor will not fit the 2.5.
Anybody know about the fuel line ???
anthony3478
Trusville,Alabama
Hey are you looking for the hard plastic line? If so I just replaced mine to day I used DOT air brake hose from NAPA
