jrou111
- 1
- 0
- Birmingham, AL
If the $350 includes the feet I'm in. I would also want a set of feet for a CUCV.
A MIG (GMAW) weld properly made with the same filler as a Stick (SMAW) weld has the same strength and characteristics, for the most part. You may be able to argue that the heat affected zones are a little different, but other than that a MIG weld proply done is in no way inferior to a stick weld.Looks good! I only have a small question for you that might have been over looked.
Are you MIG welding them togher? I only ask because I have done it, and took class's on welding and learned that MIG welds are prone to cracking under this type of load over a very short time. This is why 90% of the time that everything in our chemical plant is Stick welded togher. It is more willing to "flex and give" where a mig weld would crack and brake.
root pass with 6010 (which is a deep penetrating rod) and cap with 7018. You're right about 6013 though. 6013 is mainly used to weld thin stuff.
Code work on pipe is an animal unto itself and they have their reasons for specifying stick whether it's a 5P root/7018 fill and cap, TIG root, whatever, but if the person is competent, I wouldn't give second thought to a MIG welded bar. That's assuming he isn't trying it with some 120V machine.
Look at all the welds on large earthmoving equipment, the largest cantilevered bridge girders, ships: MIG welded.
Oh, and 7024 is a flat to15 degree rod only. It's got a high deposition but a low penetration, so it aint getting in anywhere.
You hit the nail on the head there. MIG if not run properly can cause problems, especially form cold starts or lack of attention to penetration.Its just that from What I have seen, that unless your Mig is running "perfectly" I have seen welds crack insted of flexing.![]()
$350 includes the feet to fit a deuce.If the $350 includes the feet I'm in. I would also want a set of feet for a CUCV.
That's very commendable of you to do that. I applaud you for thinking of your employees so highly.The project just helps keep me from having to lay off some of my shop guys in these hard times if I can at least cover their salary.
I've got some good people and I'm going to need them when things pick back up so I'm trying to hang on to them if I can. Alot of our business is tied to the auto industry and building industry. That's what's killing us right now.That's very commendable of you to do that. I applaud you for thinking of your employees so highly.![]()
Yes, you are right about the hole not being in the center of the first one. That's the way the military towbar is made and I patterned it after that . Don't know why the military one is made that way. The legs are the same length from the center of the lunette to the end where the feet attach so it will pull straight.One comment on your pic of the first prototype. Keep in mind I have never used one of these so I may be way off base. The lunette seems to be off center compared to the duece suggesting one leg is longer. I would think that would make the towed vehicle turn harder one way or the other.
For the legs you are makeing, would it be reasonable to use telescopeing material so they could be used with several different tow vehicles?
I don't know if I can make it but I'm going to try. If I do I'll bring some towbars.You coming to Aberdeen?? Bring me one. In fact bring all you can, I know they will sell...
OK. Sorry for the misunderstandingThanks for the update. The telescopeing leg I was talking about was the 'leg' you are offering to hold the lunette up in the air when hooking up alone.
I like that idea. I doubt I would ever be hooking up solo. Maybe, but I doubt it.or make it a "option"
