Here is my 14 bolt disc brake conversion.
I used all 1 ton parts mainly just to see if I could do it....I also was not pleased that the 3/4 ton kit had problems with both the studs and the fact that the rotor did not have any place to sit on the hub.
I solved these problems using 1 ton dually rotors and a machined ring that fits between the rotor and hub. and as you can see I made a spacer to take up the gap between the axle housing and the caliper bracket.
also here is a list of GM parts I used for anyone that wants to know what they are.
3977397 HUBS Rear Wheel
9428908 GM INNER BEARING & RACE
15702309 HUB SNAP RING
7451928 GM OUTER BEARING & RACE
9436881
ROTORS 1985 Chevy front dually
CONCENTRIC RINGS MACHINE SHOP
3988538 GM WHEEL STUDS 16
469694 SEAL
15665667 CALIPER
15665668 CALIPER
BENDIX PADS
Caliper bracket 1985 Chevy Dana 60 right and left sides
12338037 CALIPER LOCK BOLT
14023437 SPRING
14023439 KEY 2
462813 SHIELD
462814 SHIELD
341509 Spindle nut
12471641 Axle gasket
Brake lock I used
MICO, Inc. : Innovative Braking and Controls Worldwide
20 lbs each before.
http://i80.photobucket.com/albums/j184/mag-lock/7x134_500.jpg
10 lbs each after.
http://i80.photobucket.com/albums/j184/mag-lock/7x134after2.jpg
Pic Below is mocking up the rotor / caliper to know how thick the adapter needed to be.
http://i80.photobucket.com/albums/j184/mag-lock/14BOLTCORP1.jpg
http://i80.photobucket.com/albums/j184/mag-lock/14BOLTCORP2.jpg
http://i80.photobucket.com/albums/j184/mag-lock/14BOLTCORP3.jpg
http://i80.photobucket.com/albums/j184/mag-lock/14BoltLeftbare.jpg
http://i80.photobucket.com/albums/j184/mag-lock/D60CBRACKETINSTALLED2.jpg
http://i80.photobucket.com/albums/j184/mag-lock/14BoltSpindleAdapterLeft.jpg
