Wanted! 5 ton winch extentions
Capt Pat
140
Sandusky, Ohio
Hey, I could use a set of frame extensions, my M-62 was robbed before I got her, and while I'm aquiring other things have not come across these yet. Looking for both in and out, so let me know what extras you might have. Thanks
grounded
Banned
928
defiance oh
CS what ever parts you dont need i could use for my M818 ;)
Tim do you have any more 5 ton winch parts available? i need to build a winch for my tractor
5_TON_TOMATOE
OLYMPIA/WA
Any pics? I also have an M-62- 1953 IHC :-D Always interested in seeing others. Thanks
citizensoldier
19
Northern Michigan. Smelt City
Tim wanted $100 for his set when I chatted with him.. Sorry Tim to rich for my blood so I am still looking.. On the 5 ton you have a set of outer rails the same size of the frame dogs and a inner set that slides inside the frame and outer extensions reinforcing this for the winch application. Look at the pictures in the beginning of this. I show a set of the outers butted up to the frame. Its a bit different than a M35..
timntrucks
146
Ponchatoula LA
i have everything needed to install 5ton winch except,, no cable,hook,chain,shaft... i have the winch. pto,shifter,both inner and outer extentions
