will a jeep wrangler fit in the bed of a Deuce?
blackwater1
ft myers fl
will a jeep rubicon fit in the bed of a Deuce. and if so what is the best way to secure the jeep?
would would anyone be interested in driving a Deuce from redstone to peoria il next week?? (around may 19th):?:
monkeythumbs
Troy,Ohio
How come your location says Florida but you're going to Ill ? If it wasn't right before Aberdeen I'd go, but sorry I can't help you out.
dc3coyote
19
Chattanooga TN
Sorry I just took my last bit if leave before the Ga rally.
As for tieing down your jeep, is your new duece a dropside? If so just use the inbed mounts.
Hope this helps.
Branan
1,163
Hope this helps.
Branan
Does that mean we will see you in October?
BFR
Rocket Surgeon
2,330
42
North Georgia
It depends,
the inside of a M35a2 bed is 147" long
a stock SWB TJ is 156"
a stock LWB TJ is 167"
a stock SWB JK is 153"
a stock LWB JK is 173"
Both the SWB Rubis would fit with, but you wouldn't be able to close the tailgate. The LWB TJ might put the rear tires on the tailgate, and the LWB JK... get a trailer.
Travis89xj
Gainesville, Florida
the center of axle to center of axle on a standard tj should be about 90" my cherokee center to center of the axle is about 106" and i extended it out some factory is about 102". a tj should fit pretty easy
Blythewoodjoe
56
Blythewood, SC
For what it's worth, I moved my 88 wrangler in the back of my deuce years ago. I had to remove the front rack so the bumper could go over the bed a little to get the tail gate shut. I shut the gate, and drove home. No tie downs at all. I did not get to visit with any law enforcement, fortunatly:-D. If you remove the troop seats you can probably pull something off, but your jeep my be a little different than mine.
Good luck.
BFR
Rocket Surgeon
2,330
42
North Georgia
BTW the lengths I gave were overall (forwardmost edge of the front bumper to rear edge of the spare. On my TJ I could shave several inches off of that number as my bumpers and spare are higher than the bed sides and tailgate.
SWB TJ WB= 93.4"
LWB TJ WB= 103.4"
SWB JK WB= 95.4"
LWB JK WB= 116" (which is 6.5" longer than the WB on my wife's Jeep Commander)
wreckerman893
Possum Connoisseur
15,647
2,140
A 2005 Ford Ranger fit in mine without side racks. I backed it in off a loading dock and the tailgate would not close but I could get it about half way up and secure it by putting the hook through the handle. I then ran a ratcheting tiedown strap from the slits where the tailgate hooks go and cranked it down.
Put wood chocks in front of the wheels. She rode good all the way back from Arkasas.
blackwater1
ft myers fl
thanks to all for the info ------ for monkeythumbs-- i live in fl. have some buildings in peoria and have farm in iowa where the deuces will end up, but if i can get them as far as peoria - i have some people there that can help me get them to iowa:-D
816
19
Universal City, TX
I had Z Rails (or K rails) installed in the bed of mine. They are the same thing you see in the back of CDL vans or semi trailers to tie down loads. It worked great. The load limit on those (depending on which one you get) is about 3-5 tons.
