- 9,576
- 211
- 63
- Dickson,TN
I was looking a my m49 parts truck today (mainly the t-case PTO). I'm planning on using the PTO on my M35 to power hyd for my dump conversion. I noticed that the linkage has a interlock so the PTO will only go into gear with the t-case in nuteral. This could be a problem with my dump because I may want to spread gravel ( raise bed while moving). My question is, Could you remove the interlock and use the PTO with the t-case in gear without tearing something up? I'm thinking the main reason the military added the interlock is to keep soldiers from driving down the road and forgeting to take the PTO out of gear.
