nickd
- 64
- 28
- Newport, Delaware
Are the wide style tires the military used on the TOW mule still available? What size, tread pattern and manufacturer made them?
Thanks
Nick
Thanks
Nick
goodyear made the wide tires that were on the tow missle mule.
they no longer make this tire , however carlisle does make a tire
that is the almost ,if not the same. it is called at101 chevron big biters
and it comes in the size you will need. also bill watson has new repo
rims to fit these tires, as most of military wide rims are bent, if you can
even find a set, hope this helped.
Charlie
Would you have the contact info for Bill Watson?
