ohnuts
- 1
- 16
- indianapolis in
My M35A2 (77AMGENERAL) when left one or two nights will lose all air pressure. The Brake pedal after the system has bled down will drop to the floorboard when depressed with no resistance.
After the truck has started with almost no air showing on the tanks. The Pedal responds after one pump and is rock solid.
My M185A3 with empty air tanks before start-up has a firm brake pedal. With empty tanks the M185A3 is like a rock and feels just as good with 60 to 120 psi. Now I have never tried to move either truck with empty tanks. But one member said a brake pedal was more likely to be soft while there is air in the system.
So far I have fixed a couple bad airline connections. Replaced the regulator and fixed a leaking air pressure alarm switch. Flushed the brakes and filled the system with a pressurized tank. Felt great till left over night.
Is the brake pedal supposed to bottom out with no air pressure? If not (Master cylinder seems tight) then why does the M35A2 drop. The M185A3 hasn't dropped a bit in a week?
Will a bad slave or airpack drop the master cylinder and brake pedal? But drive great?
