Vic-1 system is a go!!!
Sevo
Roswell, NM
Got my Vic in last week just in time to do a recovery of my 109 in winder Ga. I went with Ferro ( adam) and it made the trip a dream. I really enjoyed being able to listen to my I-phone and not have to yell at each other.
Thank you to all the members of SS that helped me sort out the cables and what I needed. I have my radio in the car port that is going in next.
here she is
CARNAC
The Envelope Please.
718
College Station, TX
Gee that 1780 looks familar.
So how did you mount your C2298 boxes in the corner of the cab? I have L shaped brackets originally made for the M715 for the shoe box matching unit. Since I could never get them to sell, I used them to mount the C2298 boxes and the bolt pattern is virtually a perfect match to the back of the cab.
Glad you found all the cables. Enjoy
Sevo
Roswell, NM
Carnac,
I am saving the AM 1780 I got from you for my 109.. that one you see in the picture is another one I have. I will be setting yours up soon. I will post pics of it in my 109.
The drivers side box is mounted on the corner bracket that is on the deuce to the left of the drivers seat ( its that angled flat bar) . I wanted to be able to control the driver box while driving and having it there makes it easy to do that, I just bolted it to the metal that was there.
The passenger box I welded up a "L" bracket out of some flat stock and mounted it right above the seat. I was going to mount it in the same spot as the driver but the bench seat took up to much so there was no room for it there.
Sevo
Roswell, NM
Wow Chris you have to show me how to put that setup in my 109! I hope to see you in Uharrie!.
Thanks man.. Will do, it is so easy to do. The only thing I had to make was the "L" bracket. I will be at Uharrie for sure.. going to give you a call today.. got your PM.. thank you for sending me it
see you soon
Sevo
Roswell, NM
Forgot to mention to those who are installing your VIC system without a radio. You must have the "installation switch" turned to "int only" if you don't the Vic will not work..
Wile E. Coyote
81
Lynden WA
Also, once you hook the radios up make reaaaaaal sure you've followed the wiring instructions in the manual exactly or you *will* let the magic smoke out. One of the local collectors has smoked three of them in the last couple of years (because he insists on doing it himself), and each has one of the contacts on the main rotary wafer switch burnt clean off as a result. Once that happens you're pretty much dead in the water unless you can replace the switch or live with having it permanently wired up on one setting.
