m818 wont shut down
trooper632
Utopia, TX
This is the problem.... The m818 engine wont turn off using the battery switch or the ignition switch, I have to pull the emg. stop cable to kill the engine . Then lift the hood and puch the cable back in. getting to ba a pain in the butt. What's the problem?????.
swbradley1
Modertator
1,759
Dayton, OH
Donny,
I thought that was how you are supposed to shut them down????
Pretty sure that's how we did it up here when it was loaded.
sw
trooper632
Utopia, TX
Doesnt make sense to do it that way, that means the driver would have to get out and open up the hood every time. The m817 that you helped with shuts off with the ignition switch or the battery switch, I also have a duece, and it turns off with the battery switch. This one is an m818 I just picked up.
area52
San Bernardino CA
Follow the stop cable back to the actual valve on top of the injection pump. Right below it is an electrical shut off valve with a small knob pointed forward. That knob needs to be unscrewed (in the out position if that makes sense). If its screwed in the valve stays open. When you shut off the ignition switch that valve shuts thus shutting off the fuel.
edit spelling
Desert Deuce
17
Chino Valley, AZ
Area52 is correct. Check the screw on the front of the solenoid. If that doesn't fix your issue, it's the solenoid or an electrical problem toward one of the two switches on the dash. Either switch, when turned to off should kill the CUMMINS NHC 250 that's in your truck.
oilcan
Ohio
edit spelling
Just to help clarify, that knob is there to let fuel flow through if the electric solenoid ever quits working. If you turn the knob to "off" and the truck won't run, the solenoid needs replaced.
73m819
325
gainesville, ga.
the fuel shut off solenoid swells with old age, causeing it to eather not shuting down or not opening up, i put a spring on my manual shutoff so when pulled if needed, it will open up on its own with out going under the hood,, that way if the fsv goes bad and i have to turn in the over ride, i can start and shutdown from the seat
trooper632
Utopia, TX
Hey guys, I wasnt home so I called my brother told him your advise and he looked and sure enough turned the screw in on ip pump and that was the problem. But i dont understand why the screw would be in
WillWagner
2,758
Monrovia, Ca.
Sometimes the screw needs to be in if you don't have enough juice (electric current) to open the solenoid valve or if it fails ( closed).
Some of the 5T trucks have a shut off cable like a deuce. The lever needs to be reset after every shutoff.
trooper632
Utopia, TX
noticed after turned the screw in, it seems to idle differently, seems to go between 500 and 700 rpms back and forth, and when i push on the accelerator pedel it has a hesitation before it revs up at first, then it seems to rev up just fine . wonder if this solenoid needs to be replaced.
rhinob
Ijamsville, MD
Not sure if I missed it......where does one get a solenoid for the Cummins 250 injection pump? Mine sometimes won't start. I play with the power switch a couple of times and it will eventually cause a big 'CLICK.' This usually means I'm in business and it will run. It's also sometimes slow to shut down. So where do we get this solenoid?
Thanks,
Den
M818 Tractor
