I have an overheating issue. The radiator cap failed a pressure test, it will not hold at just below 15PSI. I want to pressure test the cooling system as well, to look for any leaks. What is the correct PSI to test the cooling system? I will also be replacing the thermostat and flushing the cooling system with Thoush.
How do I bleed air from the system after I refill it, when I am done with the project? I could not find a bleed valve in the service manual.
Thanks.
Thanks.
