Jones
- 83
- 48
- Sacramento, California
The holding valves do stick and/or get dirty but they're pretty straightforward and come apart easily for cleaning. By all means, try cleaning them first; new ones are close to $200.00 each and every ram has one.
HEMTT Helpful Hint # 26: if you got the outrigger assy too, all the holding valves are the same.
Another thing to consider is that they need a minimum (crack) pressure to release and you may not be getting there. All that should be in the stuff I emailed you.
Somewhere around here I've got shipping weights from Oshkosh for the crane assy. and the outrigger assy. Will try to look them up for you.
