Link to great deal on CCKW W/W (in CA)! $1000
DMgunn
SE North Dakota
1943 GI 6x6 - $1000 - Pirate4x4.Com Bulletin Board=
The pics aren't coming up on his post, but he sent me a couple. This truck has a ton of potential, and I would love to see it go to someone here before someone on Pirate......he is in Fresno County, CA - way too far for me, or I'd be trailering it home by now..
emr
24
landing , new jersey
How much does he think its worth restored? it is not that great of a deal, sorry. A mint one goes for 7 to 8 and are in the classifieds in the MV mag all the time . It is going to cost alot more than it is worth to restore, Unless U find someone that really needs alot of the parts that are on it that are good, I do have an informed opinion, But like everything else, it is worth what someone will pay for it...Good Luck . I hope it does go to A good home...Randy
NDT
6,233
Camp Wood/LC, TX
A closed cab Jimmy in that nice condition is worth a grand any day. The cabs are usually a mess.
DMgunn
SE North Dakota
I would think the winch would be worth a few extra bucks.
Trucks in that condition are pretty hard to come by in my neck of the woods, so I guess out here we pay "too much" when something decent comes along.
DMgunn
SE North Dakota
Sounds like the price is pretty negotiable - he saved it from certain death, but doesn't need it - like most of us, he just couldn't bear to see it destroyed, and "had" to intervene. He doesn't seem to have any real interest in the truck, as his interest is early Bronco parts, if that helps anyone....
Email if interested is (randykuykendall@ymail.com), and obviously his name is Randy.
2,420
DM...I paid $500.00 for one that was in FAR worse shape than that.
In fact compared to mine...that one is restored!!!
If it were around 200 miles from me I would prolly go look but CA is out for me.:cry:
1,127
Ok, you Jimmy guys help me out here. I love these things (and the Studie US6) but I know almost nothing about them.
This is an early model becuase it's enclosed and it's a 353 because it's the long wheelbase. Right?
What's the difference between banjo and aplit axles and is one better than the other?
Do all the enclosed cabs have the civilian dash?
68t
55
Michie, ,tn
that a good deal on a cckw, i keep up with the ww2 m.v. , but they just for keep our history alive or parades and shows.
NDT
6,233
Camp Wood/LC, TX
The CCKW was made between 1941 and 1945, the open cab was introduced in 1943, and was gradually phased in. The long wheelbase (353) and short wheelbase (352) were made the entire production run.
The truck for sale looks to be a '43 but it could be a late '42. You can tell by the brush guard that is exended on the driver's side to cover the blackout drive lamp. '41s and early '42s were symetrical
The banjo axles were made by GM and are known to carry greater weights, but the transfer case uses ball bearings and is considered inferior to the Timken used in the split trucks. The split axle is make by Timken, which later became "Rockwell". For hobby use the axles are just fine one or the other.
Only the '41s had the civi instrument cluster, later models had the usual round gauges. The actual dash board is the almost the same, a few detail differences.
Hope that helps.
1,127
Hope that helps.
It is a great help! Thanks!
So the transfer case is axle specific? How do you identify the different axles?
NDT
6,233
Camp Wood/LC, TX
The banjo axle is a "front loader" with the distinctive tic-tac-toe web cast into the the cover. Same appearance as the G749 "Hydramatic" trucks of the 1950's. The split is, well, split. There is a left half and a right half to the entire axle. There are some good pictures of this axle disassembled on the "Burma Ford" thread.
The transfer case is very much axle specific. The banjo front output is reverse rotation.
paulfarber
19
Gordon, PA
The interior looks ok-ish. A big area of concern would be the gauges. Also, the picture doesn't really show a winch lever. That would be between the steering wheel and shifter. PTOs and shafts are kinda hard to find.
Open cabs started production in late 42, but closed cabs were produced throughout the war.
If you need the parts then its a good parts truck. But hauling it is going to turn a $1k truck into a $3k truck FAST. Esp if you are on the east coast.
I'd part it out. Without a bed its restoration value is little as a whole. Plus whats under the hood?
1,127
Thanks NDT!
paulfarber
19
Gordon, PA
The winch lever should be just to the left of the shifter. There is a hinged plate on the floor and the lever is a flat bar that comes up about half as high as the shifter.
I had a dump truck that had the PTO lever.. its not a simple affair to add one... lots of brackets are needed. And if you buy this truck thinking it has them then you may be in for a surprise.
Now the floor *could* have been patched to welded over.... that's always a possibility... but the floor looks stock.
Easiest way to figure it out is look for the truck SN just above the passenger side shock. Should start with CCKW-353-XXXXXX-XX The last two letters should be -B2 Banjo axle with winch.
billyclanton
Memphis, Tn.
I've seen a lot worse. My G506 has the PTO flat lever and I don't see one in this cab. Mine also has the PTO knob on the left lower side of the dash but I'm almost positive that was added. Boy, there is some foul language on that "pirate" site. Ain't used to seeing that connected to this site or the "G"
Billy
