Jefferson City 6.2l engine - WON! anybody want ahaul it for $100?
Milkman357
15
Des Moines, IA
Well I won and 6.2L engine from Jefferson City.....
Anybody wanta haul it? Maybe your gonna be there anyway?
I do have tow bar available if you need to tow home you CUCV...
Maybe you bought something else, room in the back?
If I drive down I will have room in trailer for another engine crate......
$100 or you can have a starter....?
Chief_919
100
Western NC
Cool, Do those come with the injector pump? Is it out of a hmmwv?
I was down there about 80 miles south picking up a parts m1009 last week.
That one does have an IP, and it is from a HMMWV (you can tell as the intake and exhaust manifolds as well as the fan clutch are different) based on the pictures.
I have purchased several like that, and use them for parts and sell off what I don't need to buy other parts. You can use the 24V HMMWV IP in a CUCV by swapping the top covers with the solenoid. My 94 civy pickup even has a military 6.5 under the hood now.
Milkman357
15
Des Moines, IA
Only bidder...
I bid $150 and won.....comes to $177 with tax and %10...
I will spend at least $120 in gas too......
and 10 hours of my time......
NOW its getting expensive!
What's it take to test run these?
Chief_919
100
Western NC
I am toying with the idea of trying to test run one in the container. At a minimum you will need-
Starter with 24V (or a 12v starter)
24V swtiched to the IP
24v to the glow plugs
Fuel in and the return line, I suggest an electric pump.
Bypass the oil cooler lines
Radiator or a seatdy source of cool water
belt to turn water pump
make sure all the sending units are in place or plugged
A oild pressure guage somewhere in line
kennyw
Stones Throw from Reiter, WA
For a short test run of less than a minute, there would be no reason for the radiator, coolant or water pump to be hooked up.
Chief_919
100
Western NC
True, however a short run without coolant you are also likely to miss a cracked head, block, or blown head gasket. Given that these engines were removed for one reason or another, I think it is prudent to do a full test run if you are going to bother.
southdave
ripley, oh/TDY Lordstown,Oh
pardon m62y confusion, but I thought that 24 volt is only concern with the starter side of the harness. the reason i ask I just droped a 92 eng. block# K212 came out of GM truck plant I assumed drop eng. swap starter and go. I know this is gone over and over but there still seams to be alot confusion on this the scheme. same to point that way I read 11.2 volt @ my injector fuel cut off 10.3 @ the glow plugs and 25 volts @ the starter ect...
Recovry4x4
LLM/Member 785
1,807
GA Mountains
In order to ground hop in in the can you will have to modify the right rear mount to clear a starter.
Milkman357
15
Des Moines, IA
Very good
Alot of good info....
I Have to modify the engine crate, buy a fuel pump and starter....hmm I guess my curiosity about the condition of the motor might have to wait for a long time.....untill I need it. :cry:
Thanks for the great info.....as always SS is great! :-D
I was hoping it came with a starter...
6X6 ALL THE WAY
Winfield Mo
man i don't live to far from jeff city, have picked up a few things from there. I'm headin up to rock island tomorrow night to pick up a few trailers. would have been happy to bring it to you.
