Road trip to Alaska
So what do you think of Ferro's Trip?
  • I'll convoy with you!
    Votes: 34 15.6%
  • Stop by and have a beer when you pass through
    Votes: 64 29.4%
  • Good Luck
    Votes: 91 41.7%
  • Don't do it
    Votes: 0 0.0%
  • Ferro's lost his #@%^* mind
    Votes: 29 13.3%
neilhendrix
Reidsville N.C.
:funny:
go for it but i wont be going with you. i would extend the time off because you don't want to be pressed for time and you need to allow for 2-3 days of rest time when you get back. and i need to say this last thing............................ARE YOU NUCKING FUTS!!!!! YOUR BUTT I GOING TO BE SORE FOR WEEKS!!!!!!!!!:wink::wink:
Adam ,Instead of takeng xtra windshields. just make you some guards like your head lights, 2x2 frame , expanded metal cover, We had this done for riot duty when i was In service,
Got the gen set running,,
going to get the 109 on the 25th
Neil
Ferroequinologist
Resident railroad expert
4,812
748
Liberty Hill, SC
Started to install the cab heater today, only got as far as unpacking the kit and fitting some stuff up.
Wish the directions were a little better. I think I have to drill holes to mount the diverter box to the firewall?
roscoe
Spencerville, Indiana
Like was mentioned earlier, you could probably get some sponsers to help with the cost. Try outdoor outfitter type business among others. If you came through NE IN and stuck my logo on your truck for the trip, I'd give you a tank of fuel. All you need is one or two of these in each state you cross and you got it made.:-D
cranetruck
94
Meadows of Dan, Virginia
If this is the fuel burning heater, remember to install a separate fuel tank (Jerry can) for it, it will not tolerate veggie oil and probably not even biodiesel.
Installation below shows a solution where the pickup line can be moved to the Jerry can if the main tank ends up with a mix of fuels not suitable for the heater.
Ferroequinologist
4,812
748
Liberty Hill, SC
Hey Bjorn,
Is that the stock location for the jerry can? Makes it pretty handy to the tank. :wink:
Nope, it is a coolent heated heater. I have several new kits, so that's what I'm installing. Thanks for the cool tip just the same. :-D
cranetruck
94
No, it's my own work, I don't even have the correct fuel tanks for this truck. They were both missing and made of aluminum, most go to scrap pretty quick.
PS. Don't expect to much use of the coolant heated heater, by the time they start to put out, the engine alone will keep you plenty warm. :)
Csm Davis
406
Hattiesburg, Mississippi
We want to go with you!
I have my friends m35 that broke when he tried to take it home to Alaska, me and one other mv owner are wanting to drive up also if we can convoy with you we can be good people to have along. the m35 has been modified with dual tanks electric wipers, under exhaust piping, floor insulation, and has military installed seats unlike I have seen, it had a output shaft failure on the transmission which I am fixing,the other truck would be a m818 in like new condition pulling a 53 foot container we may have some extra room or not he is moving up to alaska permanently we will be making two trips at least. contact me if you would like some more hang alongs.
roscoe
How big is said logo? I'll do it. I'm still working out the details trying to find some sponsors.
I would probably just have a 1x2' magnetic sign like I put on my trucks. Makes it easy to remove. It would be more for fun on my part just to see you make it. Catch is, you would have to drive near me so I can see your setup and fill your tank.:-D
grizcty
Alaska
Great idea, and nice job.
grizcty
Alaska
C
Two years ago, on August 9, 2007 (the day after my 50th birthday) I was blessed to recieve a suprise triple coronary bypass. Thankfully, the damage to my heart was absolutely minimal and the arterial problems have been wonderfully corrected. I am in better shape now than before the surgery.
That being said.....
While I was in surgery, they stopped my heart TWICE. I believe (more strongly than any experience I have ever had while conscious) that I was on my way to "the other side". I now KNOW (absolutely without a doubt) that there is nothing to fear in death. I was "sent back" as it was not my time to die. I am more at peace with life now. I know that this life is temporary. And that is a reassurance I had never before "known".
Someday I will find the words to better describe my experience. For now, suffice it to say that I no longer have just a simple "belief" in an afterlife - I now KNOW that there IS Life after what we have here. It is a knowledge beyond simple faith.
Hey partner,
Could you send a picture/brand of the electric wipers.
I need something better in my truck!:cry:
cranetruck
94
hardtime
Bailey, Co.
Greetings Ferro,
Sounds AWESOME!!! I used to live in Fairbanks and may provide some useful tips. We have made the trek several times back and forth over the years. The last time was in Feb O7 with our 1979 Ford 350. First off the Canadian border Gaurds inspect most all rigs. I have been asked to untarp/load my stuff for proper inspection. They can be extremely overbearing at times or not fool with you at all. The Mounties are the same. Once I pulled into a rest stop way up north at 2am to get some rest and I was threatened that if anything happened to the rest stop that they would know who to look for then proceding to wake my wife up and ask her if she was with me at her will. LOL, I find that grinning and bearing these situations and politeness is the best defense. The veggie oil is a great idea (had a ford up there that ran on it) The 55 gal drums in the back may be an issue at the border, check into it. Definately no guns! allowed through. I made extra fuel tanks for the rig and were a blessing. The milepost as mentioned is a MUST. It gives you distances between towns and services and very descriptive on what is up ahead and road conditions. Be advised that things change and depending on when you actually go some places close early and open late or not at all. The book said there was a year round gas stop ahead, It was boarded up tight. Wound up poking around and buying fuell of some native kid. Another time had to wait till the next morn to buy fuel. Good tires are a must. Never had a problem but the roads get pretty slick and muddy. I would definately insulate the cab for noise and heat. extra windshields are a must. Log trucks and big rigs on gravel roads put your windshield at unreasonable odds.
If you could work out more time the better for you all around. Driving those roads can be exhausting at times, also you will see the most beautiful places on the planet there and may want to make an early day to stop to enjoy it. ( As from any mechanical issues as mentioned before)
The Haul road north of Fairbanks is/was gravel and has many rough spots. you can encounter hordes of cariboo, to road construction, to slow heavy trucks. I used to work for a heavy haul outfit up there . The average load is 200,000 lbs and slow. I can be very slow moving up there. 30mph will have you feeling like the Apollo 13 comming back to earth. You will feel like you are on another planet and will cherish it for ever.
Definately check into what it takes to get into Prd. Bay, as mentioned before there are stipulations on public trafic and such. You may have to contract a tour co. to get you in. It probably will tell you abou that in the Milepost.
This will be amazing adventure for you. I have several friends that work up there in Fairbanks as seasoned mechanics/welders and may be of assistance if need be. I will keep in touch with your post and drop you contacts as time gets nearer if you like.
I hope this helps and if you are comming through Oregon you can count on a place to rest and all the food and beer you can muster before you launch into the last Frontier.
Good luck on the preparations that is key to a trip like this. I will try to post some picts to aid in the motivation dept. Please feel free to contact me with any questions.
watrousmark
Antioch Tn
When you come up through NC and TN I hope you take Deals' Gap. I could get a few Patriot Guard folks together to escort the convoy. It might make a nice start to your trip.
