- 34,012
- 1,807
- GA Mountains
Folks, I need a little help here. When the GA Rally comes around I'll be picking up my M1008 from Papercu on the way. I'll be flat towing this machine home. I don't do well removing drive shafts so my plan is to remove the axle shafts for the 700 mile ride. What I'm looking for is the dimensions and bolt pattern of the axle shaft flange so I can brew up some block off plates. I'm also curious if there is any part of the spindle or spindle nuts that extend out beyond the flange of the hub. If it does I'll need to machine this area out to clear. I'll be putting a pipe plug in the plate so that I can add a little GO after the flange is installed. Pics a plus!
Thanks in advance!
Thanks in advance!
