jag7720
- 2
- 0
- Kansas City, MO
Does the oil pump make any noise when it is starting to die?
So you are saying the oil pump on a 6.2 is a piston pump and not a gear pump? I've never been into a GM diesel but every other GM engine I've been into had a gear pump. I'm not saying you're not right because I don't know but it just seems odd to have a piston type oil pump.The oil pumps action is one by a piston/rod being actuated up and down by the crank shaft to pump the oil.
Any failure of the oil pump would not be making the noise you are hearing, as far as a, buzz or a whine. If anything, it would be making a knock type noise.
I would probably do what "reloader64" suggested in his response and I'm sure you'll find what you’re looking for.
