Drain coolant.
Remove upper brace running from radiator "frame" to front of cylinder head.
Remove upper hose.
Remove fan (careful not to damage fins).
From underside, disconnect lower radiator hose at the radiator.
Curse Engineers for putting lower hose in such a place.
Remove grille guard.
Remove 2 nuts on the long studs which hold the radiator to the front motor mount.
Lift radiator up, careful not to damage the threads on the long studs.
As long as it it is out, check front of engine for leaks, or needed repairs or servicing (now is the ideal time for a leaking front crank seal, etc.). Check belts and hoses.
Reinstallation:
I found what was easiest for me was to lay the radiator on top of the front motor mount plate, the studs not in the their holes; push the lower hose onto the radiator, then wiggle the radiator studs into the plate. Once it's in, you can snake your hand up in their and tighten the clamp for the lower. Don't forget the springs and the ground strap on one of the studs.
Up top, go ahead and reinstall the fan now, while the radiator is still loose and has some play and can be leaned forward. Once the fan is in, do the upper hose, then the adjustable rod running from the front head to the radiator frame. Now you just need to tighten the nuts on the lower studs, check all your connections (bolts, hoses, clamps), refill with water and hope it doesn't leak. If it doesn't leak, reinstall the grille guard.
Payment for services is accepted as paypal, cash or MV parts.
