rmgill
- 14
- 38
- Decatur, Ga
So I bought a pair of the Korean made windshields at the GaMVPA rally from Kevin Emdee/Star Electric Ordnance. I installed one the other day at the event and got the other installed today. I tweaked the first one to get it done right and once adjusted, they seal MUCH better than the standard US made Windshields. The rubber seals around the edges are continuous in a 'U' shape and the tops have a set of rubber foam seals at the corners to aid sealing of the upper hinge strip.
When closing them you DO have to check to see if the windshield is centered but you can easily do this when closing the window.
