Prerunner1982
- 1
- 0
- Edmond, OK
I will come to wheel the Jeep...So does anyone plan to work on anything.......if not your all working on my Jeep!
![Very Happy :-D :-D](https://www.steelsoldiers.com/images/smilies/icon_biggrin.gif)
I should have called I suppose. They siezed up while I was driving. I can't really seem to trace the problem. The brake pedal gets as hard as a rock and the thing won't budge, and draining the air from the system doesn't fix it, but it usually returns to normal within a few hours. Any ideas?What happened to your brakes? You should have called us, we would have met you in Eakly with tools in hand!
Blead your brakes, I had a similar problem with my 818, I had a blockage in the line at the rear axles that was not letting the pressure release from the wheel cylinder....once it start to heat up the fluid expanded and locked them down. When that happened my pedal was rock hard.
Have someone stand on the pedal with the truck running for air assist, blead each wheel cylinder, find the one with low flow and watch out when it clears itself!
