steve9257
- 0
- 0
- Fayetteville/TN
Happy days! Just purchased a 1987 M35A2 from GL. The truck made the 300 mile trek from Warner Robins back to Tennessee with no issues. I did notice a couple of things that have me a little worried. I spent several hours reading through all the M35A2 threads and did not find any mention of these issues. First, the steering. The truck drives straight and true. Whenever you initiate a turn, the steering wheel “slips” (turns very easy) and then engages. This is somewhat unsettling when you make a left or right turn and feel the slip. Like perhaps something is about to break. I did some checking by following the linkage and found no issues with the linkage. The steering box does emit a low popping noise with slip occurs. Worn steering shaft spline? Or ??
Second, the clutch pedal. The clutch seems to work very well. However, I am concerned about the amount of travel (from the floor up) that is required before the transmission engages. The clutch pedal is almost at the top of the travel before the tranny engages. The clutch on my other deuce engages about half way up from the floor to the pedal stop position. Is this ok? The clutch does not slip.
Thanks...
Thanks...
