Keith_J
- 1,323
- Schertz TX
Synthetics burn just fine. It is silicone oil that won't burn properly.Everything from almost 2000 and up uses a BG products synthetic called part #2134! Synthetics are now very common, should I seriously avoid this or just dilute it better with a diesel from the station pump! I really want to try this out as I own multiple Deuces!
I would recommend diluting all motor oil with at least 50% kerosene or diesel because the increased viscosity puts a much greater load on the injector pump.
