Made my MC cap work as a pressure bleeder cap with a few things from Homeless Depot/Lowes. Use the numbers on the packages for you fellas like me who need the extra help. Other than the 4 fittings some 3/8ths clear hose and a 2 gal sprayer is all that is used. Plus some brake fluid. Duh...
1 1/8th elbow screws into the cap
2 1.5" long 1/8th male to male goes into the elbow
3 1/4 to 1/8th reducer ties into the male end leaving a 1/4" female port for a...
4 1/4 nipple to 3/8 quick connect fitting. Most garden sprayers use 3/8 diameter hose.
I know it was done before but I could have used the wrappers from the fittings since the store I go to never seems to have all the parts posted, causing me to improvise. If thats your case just remember that the opening in your MC cap is 1/8th" NPT threads and your going to have to go up to 3/8 diameter hose. How ever you do it can be up to you.
Hope this helps some.
PS I had thought the brakes had been ok before... they will put you through the windshield
now
