Cold startig
O.D. Fever
Howard City, Mi.
I have a m35a2 that hates to start below 50 deg. It has the Quick Start either system install on it. The thermistat is interuping the ground to the solinoid. I can use freeze spray on the thermistat and it starts working. I called Quickstart and asked them what temp does this thermistat close the circut? They said 70 deg.. So I orderd a new one and installed it.. Same problem. I can jumper it out, but then it might get bumped and by by engine. Has anyone else had this prolem, or did I just buy a new defective thermistat??? Joe
SasquatchSanta
27
Northern Minnesota
This is confusing. Are you saying that your ether system has a thermostat in it that won't allow the system to deliver ether to the engine above a certain temperature?
I'm not familiar with the military ether system. The civi ether shot system I added to my deuce doesn't have a thermostat or anything else that blocks ether being delivered.
SasquatchSanta
27
Northern Minnesota
I guess I can see how a thermostat to safeguard some idiot doseing a hot engine with ether would be prudent given the possible attitude of some of the young troops that might drive these trucks but if it was giving me problems I'd bypass it.
I've got a generic ignition switch wired into my system that requires a key to activate the ether. I guess it all depends on how close you want to keep the vehicle to stock.
dittle
72
Albia, IA
I thought the military switch was set between 30 - 40 degrees for the interrupt. Typically a diesel (designed w/out glowplugs in this case) should not require either to start it at 50 degrees. Will it start easier if you give it some throttle at startup? Mine starts fine if I give it so I can see 4 notches on the throttle lock (about 900 RPM) but if I don't it will start, run for about 2 secs and then die. I haven't tried mine in the real cold yet, but unless needed I won't as I don't see the need to start a really cold engine just to start it.
O.D. Fever
Howard City, Mi.
Mine will start at 50 deg. but I do have to give it more throttle and it starts a little hard.. At 30 deg. the thermistat would not let it get a shot (old), don't know about the new one yet. However the Quickshot guy said 70 deg. Ill keep trying as temp drops and when it gets to where it wont start I guess ill jump it out.
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
O.D. Fever, the guy at quickstart was more than likely mistaken...the deuce thermostats are set around 30 to 40 degrees like dittle mentioned
O.D. Fever
Howard City, Mi.
I tried to start at 30.deg. and without either it would not start. I have no flame heater soooo.. its eihher or spring.. Guess i'll jump the ground...
Mark2X2
Washburn, WI
I certainly mean no offence to you guys with the ether systems on your trucks, but I would be very careful using it or don't use it at all. I can attest to the damage that ether can do to a diesel engine. My Dad used ether on a diesel farm tractor and ended up having to rebuild the engine... My truck has the manifold heater on it and it works well. My deuce started last winter when it was +5 degrees F.
We use ether on our logging equipment in northern WI a lot in winter, if you use it right it's not a problem. Keep the ether warm, spray while turning the engine over so it draws it into the motor.
Mark
Mark2X2
Washburn, WI
If your truck won't start un-aided in the 40's, you have more trouble than your ether system. Could be a tired engine.
Mark
Bigmillman
Schoolcraft/Michigan
As I recall.... The duece engine needs to turn over at 800 rpm from the starter or good luck getting her to go, then as mentioned earlier, simple diesel protocal: Fuel, do you have a good fine pattern from your nozzles? Compression, does it meet spec's? Heat: Well, I have started mine with no ether at -28 here in Michigan. Sounded like a sledgehammer trying to escape but it did start with full throttle applied.
Oh, I do change the oil to a thinner grade in the winter so she will turn over fast enough. Learned the hard way a few years back. Too thick=no turn over fast enough!:-D
cranetruck
94
Meadows of Dan, Virginia
The thermal switch for the ether start system is set at 20°F if they are all equal. I tested one I had one time.
50 deg ambient? That's not cold, you have other issues. Check the fuel lines for air leaks to begin with, bleed the lines at the secondary/final filters. How are your fuel filters, clogged fuel filters will keep it from starting.
Batteries and connections in good condition? Should crank at 200-300 rpm to start and will do so down to 10 or even 0°F without starting aids when all is up to snuff.
