They are not listed. If you read the "why did they pull all the M35A2s" thread a member received a correspondence from DRMS which stated that the have been recoded as F (must be destroyed) Apparently they are discussing
![Rolling Eyes :roll: :roll:](https://www.steelsoldiers.com/images/smilies/icon_rolleyes.gif)
the situation
Code
Description
A
DML not required
B
DML not required. Trade Security Controls (TSCs) required at disposition.
C
Remove and/or demilitarize installed key point(s) as prescribed in the Defense Demilitarization Manual, or lethal parts, components and accessories.
D
Total destruction of the item and components so as to preclude restoration or repair to a usable condition by melting, cutting, tearing, scratching, crushing, breaking, punching, neutralizing, etc. (As an alternate, burial or deep water dumping may be used when coordinated with the DoD Demilitarization Program Office.)
E
Additional critical items/material determined to require demilitarization, either key point or total destruction. Demilitarization instructions to be furnished by the DOD Demilitarization Program Office.
F
Demilitarization Instructions to be furnished by the Item/Technical Manager.
G
Demilitarization required. Ammunition, explosives, and dangerous articles (AEDA). Demilitarization, and if required, declassification and/or removal of sensitive markings or information, will be accomplished. This code will be used for all AEDA items, including those which also require declassification and/or removal of sensitive markings or information.
P
Security classified item - Declassification and any additional demilitarization and removal of any sensitive markings or information will be accomplished prior to accountability or physical transfer to a DRMO. This code will not be assigned to AEDA items.
Q
Strategic List Item (SLI). Demilitarization not required. SLI are non-MLI(Munitions List Items) controlled by the U.S. Dept. of Commerce through the Export Administration Regulations (EAR) and indicated on the Commerce Control List (CCL). Each CCL entry is preceded by a four-digit Export Control Classification Number (ECCN) and those ECCNs ending in the letter "A" or "B" are defined as Strategic List Items. These items are subject to Import Certification and Delivery Verification (IC/DV) control and other trade security controls.
