Mark3395
- 2
- 18
- Geneseo Illinois
OK, I'm back down at Papabear's shop to resume recovery of my 109 van.
History: I picked the truck up at Warner Robbins and it was a pig. It labored to run about half speed.
Changed filters and assured fuel was flowing fine. Fine help from SS guys lead me to adjusting the Fuel Density Compensator. First, I bypassed the FDC. No improvement.
So consensus was to adjust the FDC for more energy. In so doing I discovered that the guide adjusting screw... the one with the two adjustment nuts on it... was broken. No spare so I had to improvise.
I first tried putting padding under the sheet metal cover to keep the screw pushed in. No help. I resorted to drastic measures... removing the moveable stop plate (see page 1-30 and others in TM 9-2910-226-34, Injector Pump).
WOW! Ran like a striped assed ape!
That concerned me. Too good to be true? I considered that too much energy delivered to the engine could damage it so I set out conservatively... and blew a head gasket in about 7 miles. The truck's been down here since.
Troy changed the head gaskets out and found that the heads were not properly torqued. He feels that was the root cause of the head gasket failure.
I drove the truck a few miles yesterday... with the FDC bypassed and the stop plate removed. Moves powerfully, but I'm concerned I've still got a fundamental part missing.
So the questions are:
1. Considering that the FDC is bypassed, what bad things happen with that stop plate removed?
2. Is it possible to use conservative driving techniques to avoid trouble?
3. Must I replace the IP with another with the stop plate in place?
4. Is it sensible to just replace the FDC with another one that's already adjusted... stop plate and all?
If it's safe to drive, I'll be able to go to the GA rally. If not I'll need to think about this and leave the 109 behind in favor of another truck.
Thanks much for your kind wisdom.
Mark
Mark
