goldneagle
- 896
- Slidell, LA
Sorry i was not aware of the speed of the turbine motor.This is true - the output shaft turns at 12,000 rpm.
Oh HELL YES!
I've been wanting to make a small squad of 1/12 scale M1A1 Abrams MBTs because at that scale a 10 mm handgun could easily stand in for the 120 mm cannon. Get some military school cadets and head out to the coal flats and have ourselves a mini-tank battle. Of course, mine would just be powered by a pair of stepper motors and a butt-load of batteries in the belly.
And, of course, there would be technologic means to prevent a tank from firing on organic targets.
Now, the big question, how to get your hands on a M230 chain gun... Anyone have an Apache DMA can strip in the middle of the night?
Aircraft
+1Man some how rig that up to a boat. I dont know how but can you imagine the looks you would get when you put the boat in at the ramp.
Vote number two for boat.
I have sold many 28V gensets to construction companies and heavy equipment dealers who use them to jumpstart heavy equipment.
This one already being on a nice small sized trailer it is perfect for that use.
Not a DC cart. We use those to run hoists and lifts.That is an Aircraft powercart any way for aircraft starting. I am not sure though how a civilian could get ahold of a cheap gearbox to make it work. Does it have a place for bleed air extraction...... could be used to power an aircraft type air conditioner!! Exhaust temps should only be in the 350 range not 700 or so...that would be high even for a jet on an aircraft except fighters. Well however it goes keep us informed!!
