- 3,313
- 3,520
- NORTH (Canada)
I was mindlessly taking off the front brake drums after having done the rears. Beside the point is that bozo soldier A replaced the driver's side set of brake shoes while he left the right side untouched although it is worn to sh&t and two guide pins fell out.
There were no corks in the keyways and there was no outer seal on either side. I took a spare outer seal and it would fit perfectly.
I was under the impression that the front and rear hubs are set up alike.
Question: Aside from putting RTV into the keyway, does an outer seal go between the outer bearing and the inner axle nut?
YES I LOOKED INTO THE TM 9-2320-209-20-3-2. The pics show black blurbs and the text does not refer to an outer seal. So, I guess, the answer is No, but I want to make sure.
I do not understand why the rears would need an outer seal but the fronts would not.
