gmjunky87
- 1
- 8
- halifax, pa
I had a hell of a time today getting my m1008 started, it was parked up hill and i noticed a small drip at the bottom left hand corner of the fuel filter (if your looking straight at it) it worried me because it was leaking right on the exhaust manifold.
needless to say i had to charge the batteries twice before it started, i drifted the truck onto the level, cracked the fuel filler cap and alot of air came out, then cracked what looked like a bleeder screw on the top of the fuel filter that was about the size of a quarter and bubbles came out then it shot fuel out the side, cranked it, it sputtered but eventually cranked over, but the leak at the fuel filter box got worse, if someone can point me to a thread that deals with that i would be greatful! I just got this truck so i'm just figuring out things here and there. i read through the intro and found alot of helpful info! awesome!
also, how can you charge the batteries without having to unhook a terminal and do one at a time? thanks!
i'm plannin on putting an electric fuel pump in, also trying to figure out how to wire in leads that enable me to charge both batteries at the same time.
also the truck has 71k on it but the motor runs super smooth and once you get it started shut if off, it starts immediately, there are alot of new replacement parts under the hood, looks like it was well kept!
