Josh
- 12
- 38
- Portland, Oregon
So i recently started collecting some WMO, i got a couple drums of it now, and i was going to run it threw a water seperator before i put it into a larger holding tank(have yet to get the tank) well i was thinking of using this pump from harbor freight
- Harbor Freight Tools - Quality Tools at the Lowest Prices
and then running it threw this
NAPAONLINE®
but there are no specs i can find for the filter for what the max PSI it can handle are, and i cant find out what PSI the pump would push the oil at.
the goal is after i run it threw this filter and let it settle for a week or so( prob longer cause im lazy anyhoe) then i would run it threw a pair of fuel filters ( probably the same ones that the deuce uses for the secondaries), i figure this will make it plenty clean and hopefully water free.
any imput, or if anyone has tried this set up before and it works/doesnt work, help would be appreicated.
NAPAONLINE®
