area52
- 5
- 38
- San Bernardino CA
Do you have a heater inline or how do you heat the oil? Or do you?
can you post some pictures of your setup?
I disagree, I have been running WVO for years and it is MUCH cheaper than buying diesel. My setup took a few days to build but it works great and it takes me lees time (man hours) to run than it takes to cut my 1 1/2 acres of grass on a bi weekly basis. The bad is, it can be messy. the oil should be heated and run through the centrifuge, slow about 5-10 gal/hr. I get pretty clean oil and have already drained the settled water on the bottom so I just leave it running and do a 55 gal to a 55 gal transfer(gravity through the centrifuge) I do blend a little diesel but its anywhere from 5-20% depending on the temperature.
Yes, that is correct. The IP gets its lubrication from the fuel. As I understand it, the MF injection pump is made of hard, polished, steel parts, which need minimal lubrication. Even gasoline is slippery.... many an old car has an electric fuel pump that is of the gear style, like an oil pump. They do just fine with gasoline as their only lubricant.... how the MF IP will fare with gasoline only is unknown to me. It certainly wouldn't hurt to add some motor oil to help it out.As an addendum to Chuck's post above, there is some speculation on lubrication for the IP with certain fuels.
I'm in the process of assembling a rather, uh, 'large' WMO centrifuge system with a dieselcraft-style unit. Awaiting a mount for my hydraulic pump. I'll brag about it after I get it working.
Getting me to write stuff is easy, getting me to shut up is much more difficult.Stumps, now you see how long it took me asking questions to get you to spill your guts!![]()
That high flash point is the entire reason for the MF engine's ultra high compression ratio. Gasoline just doesn't want to compression ignite... and when it does, its high octane makes it burn too slowly. It really hurts your efficiency if the fuel is still burning when the exhaust valves open and the piston has to start coming back up! All of that flaming fuel burning in your exhaust system contributes nothing to your forward motion.I have always heard you need to add oil to gasoline as the flash point is too high and the lack of lubrication causes pump failure in a deuce so my.
