What does "combat starter" mean?
todds112
Teton Valley, ID
A truck description listed on a auction site states: "Combat starter. Did not start."
Does this mean they fought the starter and it wouldn't comply? Or is it a special starter that only works under combat conditions?;-)
jollyroger
Centennial, Colorado
I saw the same posting on GL last night and asked the same question of my Pop's who usually knows about everything. He looked me straight in the eye and said it's an old motor pool term that means you have to fight with the starter to get it to work. I just started cracking up cause I knew he was full of BS. Then he said he really did not know. Oh well. The mystery continues.
cattlerepairman
3,520
NORTH (Canada)
It means that the truck starts a combat between different methods of getting it started...slave cable vs. coiling a rope around a pulley and pull-starting it...
Ferroequinologist
Resident railroad expert
4,812
748
Liberty Hill, SC
You guys got this all wrong. You know the military. It stands for
COM= commercial BAT= Battery
So it won't start because it has a starter that only works with commercial batteries, and I bet the knuckleheads in the motor pool put in 6TLs!!!! :wink:
wiggall
151
Lenore, Id.
So if the starter dies in an A3 your are SOL:cry: Not like the M211's, M35, A1,and A2's can all be push, pull, and run down a hill started:-D
