need an opinion
dstang97
30
Clover, SC
I need a new starter,
Should I buy a used one that "works fine" for a $100
buy one from a local starter shop not chines poo poo for $175
new one from OD roughly $300
I have never heard this truck run should also
what would you guys do????
HardCorps79
Kansas City, MO
I would almost always prefer to buy new or remanufactured stuff, but unfortunately I'm on a lean budget. What I tend to do is buy a local for temporary use- just to keep the truck on the road, and then save up for the new/reman part for the long term. It may seem more expensive, but hey, I gotta get to work somehow.
CUCV85
central/ny
:arrow:Have the 24 Volt Rebuilt for 100-125.00
Unless your converting the vehicle to 12 volts.
Stick with the 24volt Starter, rebuild it!
They Last a heck of a lot longer and turn over faster.:idea:
dstang97
30
Clover, SC
The problem is i dont have an original starter. so i would at least have to buy the one for $100
allrevup
Delaware
dsstang97 I would buy the used one for a $100, if you know is working and up to specs. Then if and when is dead you can rebuilt it. Not 100% sure of the part numbers but, there was an early and the more dissarable later model. Good luck either way!
