For anyone wanting more speed for your deuce
355
12
New Enterprise Pa
It's a little pricey but my buddy Russ at Gearhart Engineering makes a lower numerically gear ratio for the 2.5 ton topload. It's a 5.41:1 ratio. Plus he makes many other cool stuff for the Rockwell axles also. You can checkout his stuff at Gearhart Engineering These are high quality gearsets and he has several sets in use on the western coast in a few deuces. So enjoy/drool or what ever. Lol:-D:-D
jatonka
111
Ephratah, New York
I am happy to see that gearsets are made but I can't handle $6600 for one Deuce, maybe we could all contact this guy and he might get cheaper? JT out
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
I'm with jatonka, I would love to have more speed out of my deuce with stock 900 20's, but I could buy my slow deuce 4 times over for what a set of the gears would cost. As nice as they are, it's just too much money.
BKubu
1,256
Gaithersburg, MD
Joe Young once said...if you want more speed out of your deuce, remove the radiator cap and back the truck out. Drive a Peterbuilt in and re-install the radiator cap. These trucks are not made for speed. Guys who paid $1500-3500 for their trucks and can mount monster truck tires on them to get higher road speeds are not going to pay big money to accomplish the same thing. It is called market research.
loosewrenchcowboy
farmington hills, mi
who needs highway gears?
instead of bobbing my M135, i just dropped out a rear axle, centered it in the wheelwell, used F600 springs and hangers, and built a dropped frame section to mount it all up. stock springs and hangers in the front, but built dropped mounts for the hangers. swapped in rockwells, and 16.00x20's. now i'm afraid to top her out-I've done 70mph-no problem. kinda scary though. :shock:
OPCOM
29
Dallas, Texas
If one was doing a frame-off total rebuild and customization, the 6600 would be nothing. For others, replacing the engine and transmission with one that turns a little faster, or putting larger tires on, would be enough. 65 and over is very fast in a deuce. The suspension is not made to behave well at high speeds.
GoHot229
Your friend no doubt makes quality stuff. Like some of the others, I wouldnt pay 6K for gears. Whats the point? You are bakwards engeneering here, its a dirtbike of trucks, not a road racer.... But mabe someone will bite.
2,499
I give you friend lots of credit and even admiration for being able to produce the gears but I just can't see a need or the expense personally.
As a couple folks have already stated..and I agree...the brake systems, steering and suspension and just the overall design of the deuce makes 55-60 MPH plenty fast for me.
(Maybe 30 years ago I would have thought differently);-)
If I want to get somewhere quickly I sure ain't gonna drive an MV:-D
joec
Vincentown,NJ
4.90:1 Gear Set
[1602] $1,200.00
That's right boys and girls. For the first time in its history, there is now a choice of ratios for the Rockwell 2.5 Ton Axle. Pinion gears are crafted from 9310 alloy with the "ring" gear made from 8620 alloy. Both pieces are shot peened for added strength. The 4.90:1 set includes a new aircraft grade 4340 input shaft. Gears are spiral cut and lapped for a perfect matching fit.
This is from Ouverson! You can use the stock bull gear.
but its better @ $3600 for 3 axle's still alot but but 4:90 gear set is pretty good...my2cents
joeypushjr1
tallmadge ohio
plus you gotta think you throw that gear in there . now you going to lose prescious off road power and pulling power by installing a higher gear just to get 10mph more out of your truck to me it aint worth it . ill stick to tire upgrades.
stumps
12
Maryland
Do you imagine that using larger tires doesn't cause you to lose "prescious" off road power and pulling power?
-Chuck
