PawnShopEd
- 0
- 0
- Churchville / md
Hey guys I've been working on getting all the small problems my duece had fixed for winter and in general. Got the weather stripping all in and new 60psi oil sending unit, new oil pressure gauge and turn signal flasher.... turn signals still dont work and the oil pressure gauge still doesn't work.
I put a new gauge in and then didn't know the oil sending unit could be 120 or 60. So I pulled the sending unit yesterday and put a new 60psi unit in to match the gauge. if you flick the power switch you can see the gauge move to 0 but thats all it does.
The turn signals worked when I bought the truck then became speratic the light on the colom would flash here or there and then so would the turn signals. So I bought a new flasher module, cleaned the ground cleaned the spot on the inner fender. Mounted the unit back and still nothing. I have a parts duece I took the steering wheel switch out of and plugged it in.... the light on this one lights up but there is no turn signal response.
Any idea's?
Any idea's?
