AJMBLAZER
- 8
- 0
- Paducah, KY
I sorta kick myself for not going with smaller batteries last year.
I had to get new batts for 1008 and was also unhappy with the waste of space under the hood....IN the end it still is 6.2 Smaller batts should be fine but I do like those big ones but here's a question...Has anyone successfully moved the firewall Batt to the pass side ? I want to free up space there for a possible 6.5 turbo setup. Otherwise I was thinking of tossing the batt trays altogether and using stock dual trays from a civvy model. I think the firewall batt will be in the way for my future turbo.
just put both my batteries on the rear tray. would have preferred the front one, but the cables wouldn't reachWell I took those big batteries out a couple of years ago and put civilian car batteries in....Recently one of my batteries went bad and while I was messing around I decided to put both batteries on one tray to make some extra room for maybe a veggie oil fuel heater water separator...or something.
Anyway has anybody else tried this or had any bad experiences doing this. Hopefully it will be a helpful mod.
nice to know that a fuel heater fits there, as I'm seeing french fry grease in MY cucv's futureI needed the depth ti install my fuel heater, it needs about 16 inches down, moving the batteries to the back was perfect for my new equipment, I have plenty of room to add othe things. I may have to install an electric fuel pump, I also have a crazy idea to make a smoke screen device..
Wondering where you put the coolant overflow reservoir.well, I was swapping to an st-85 so I thought i'd share the new and improved room gained by going to civvy battery trays.![]()
check my previous response in this threadWondering where you put the coolant overflow reservoir.
Walter
check my previous response in this thread![]()
