4bogginchevys
- 1
- 0
- rathdrum idaho
so basically my question is: which leaf spring is bad, front or rear.....no springs are broken. Here are the measurements left front 35.5/right front 36.75/left rear 37.25/right rear 38.5. All measurements are from the ground to the top of fenderwell opening in the center.
Basically the drivers side is sagging front and rear, I've gotten some opinions from friends and most poeple think that the LF spring is the reason for sag because it's got the weight if the diesel on it. I remember hearing that the springs on military vehicles are special for a good ride off road, are the fronts special like the rears as far as spring rate goes? I can buy add a leafs for the front for 159.00, but I would rather not start with a bad spring in the front corner. Does anyone have any springs that are good used units for sale, or an opinion that could lead me in a new direction?? Thanks
