WTB: Front axle air control valve
ken
25
Houston Texas
Mine started leaking about 2 years ago. I took it off and went to a truck parts place called TRUCK PRO. The had it in stock and it was $12. They called it a flapper valve. Although the handle was crome it was otherwise the same. It works great.
LanceRobson
206
Pinnacle, Stokes County, NC
Bjorn, how fast do you need one? I have a good used one and a NOS one in a airsfift install kit. Do you need the tubing and fittings? I am trying to finish a house so a customer can move in for Christmas and am working long hours an hour from home. It might be the first of the year or a little after before I have time to get them out.
Lance
cranetruck
75
Meadows of Dan, Virginia
Thanks Lance! No rush on this, next month is fine and if the bracket, light and the immediate fittings are included, so much the better. Just let me know how much I'll owe you.
Thanks for the truck parts suggestions, but it's nice to have the bracket and light included as well, along with the pressure switch, wiring etc.
gringeltaube
Staff Member
2,523
Montevideo/Uruguay
Tiger probably was referring to the complete assys like the one pictured??
For example this kit (Chelsea #328863X) which is not exactly military OD stuff :smile: but does include all fittings, hardware, ind. light, switch, etc. and sure is A#1 quality, " US-made, with pride....":-D
In lack of the original switches I have been using this mainly to engage the rear facing tranny PTO via a small air cylinder but also for activating the air shift TC.
G.
Divemaster920
Banned
494
VA
I bought my kit from Saturn Surplus. It had everything with it. All you have to supply is tubing cutter and wrenches. $75 I thought it was a great buy.
