Cluby fingers
chris837rj
Galveston, TX
I don't know what the time limit is but you could type your message into a word processor or email program and then copy and paste it into the message box then hit post.
Bob H
159
Huron National Forest, Michigan USA
You will need to use the keyboard " CTRL V" to paste as the forum has the right click & paste disabled.
SShhh! don't tell anyone about the CTRL V thing, cause they'll probably disable that too.
Snarky
9
Brazosport, TX
Here's the 10 step program for windows users:
1. Hold down the key shaped like a window (The windows key) and while holding down the window key, press the R key.
2. Type in the word NOTEPAD and then hit enter.
3. The note pad should should up. Inside notepad type what you want to say.
4. Once you are finished hold down the Ctrl key and hit the A key, and all your text should be selected.
6. Then while still holding down the Ctrl key press the C key key and it should copy your text into the clipboard.
7. Then go to the thread which you wish to post in or create a new one and click the text box like you're going to type in it.
8. Then hold down the Ctrl key once more and while holding it down press the V key, and it should paste your text in.
9. Reread your text to make sure it's all correct and all there.
10. Post your text.
