DaGlitch
- 0
- 6
- Albuquerque / NM
Ok to start off only Gen2 light comes on when the key is in run position, and the volt gauge is in between the red and yellow on the left (low volts) side of the gauge. I crank her over... She starts up, and Gen2 light stays on for a little bit longer, then proceeds to go out.
The problem. Gen1 light never comes on
. I tested the alternator and was getting about .45v out of it with the engine running. Tested passenger side alternator and was seeing around 25v. I JUST got the driver side alternator fully rebuilt and put back on, but it seems to be pushing the same amount of voltage from it before the rebuild. I checked the ground it seemed to be fine, as well as the battery cable. the only thing i could think of was the plug that has the brown? and red wire on it that plugs into the alt. Is it possible a fusible link blew somewhere that would cause this? I checked the ones i could see near the driver-side firewall and they looked fine. Also, what is this little single brown plug with a rubber boot around it for? The TM doesn't even have anything extra hooked to alt1.
Any help is GREATLY appreciated!!! Tryin to get a daily driver up and runnin![Very Happy :-D :-D](https://www.steelsoldiers.com/images/smilies/icon_biggrin.gif)
Pic of some of the fusible links
http://getglitched.com/images/M1009/IMG_0290.JPG
