CTM joints are great, but aren't they like 250-300 bucks....a piece?!
I'm glad someone mentioned greasable vs. non-greasable. I use non-greasable for just that reason, in theory (and it makes sense) they're stronger. Another reason for just using non-greasable is you usually can't get to the grease zerk once the u-joints are installed anyway
They're pretty easy to replace and fairly cheap compared to other things and they don't wear out that often, so it's not a huge deal that you can't grease them.
Yes, you should always install greasable u-joints so that the grease channel will be under compression (being pushed on) during normal forward driving.
The first thing that pops into my head when I think weak link with these trucks is either the hubs or the u-joint at the diff on the front driveshaft. For some odd reason, they decided to make those joints 1310s. I just don't know which would fail first, but either way it'd be an easy enough fix.
