Very good question
... here is the deal:
Having pressurized air in contact with the fluid is the problem. Air is pushing on the fluid, forcing the fluid out of the pressure unit.
This pressurized air forces itself into the fluid. This can happen at a level that is virtually undetectable to the eye as the air bubbles are very small.
So we end up putting air and the moisture trapped inside the air into our brake system! The whole reason we were bleeding the system in the first place is to get rid of air and water!!
DRAT!
Anyone who is in the business of doing alot of brake work, stores their fluid in containers which are hooked to a constant vacume, thus keeping the fluid from touching air. Them we come along with our pressure bleeders that actually force 30PSI of air pressure onto and into the fluid!
Well, sorry if I have thrown a wrench into your plans.... Like I mentioned, pressure bleeders can be great tools, but only if the brake fluid and air pressure are kept seperate.
mikey
