so got got some really big tires the other day......
just_enough
Grand Haven M.I
ha ha thought i'd share it with you all i bougth these for another project but seeing my deuce next to them tends to make the mind wonder as to how wickedly sweet a duece would look like with a set of 6 66's under it....:-D def nee hydro steering
im 6'3" and i look short next to them sideways
and the other on is next to my dads jeep.. he about pooped when he wlaked in the garage and say em
Pasaway
Las Vegas NV
so what are they going on? your own personal Bigfoot?
those are huge. if you did put them on your deuce, you'd have to start making appearances at monstertruck rallys.
Josh
12
Portland, Oregon
ive seen a deuce on youtube(cant find it anymore) running monster truck tires in the rear(custom made rear of coarse) and dual tractor tires up front.
USMC6062
St Augustine, FL
I've seen the truck in person. It is a deuce, with 5 ton running gear. It has a 5 ton T-case hooked to the back of the deuce T-case, and the rear axles are located by a homemade link suspension with air bags, I think the front was blocks and leaf springs.
wehring
26
Angleton, TX
48" terra tires
Has anyone put 48x31-20 or 48x25-20 tires on a bobber yet? They should clear just fine with no lift...
Justin Wehring
979 997 3112
Ridgerunner
Holland, Mi
Justin Wehring
979 997 3112
I have two sets of the V-treaded 48x31's, both sets with 2 1/2ton 6-bolt pattern wheels. One sets on my mud bogger. The other set is just sitting there in the barn, but I haven't put them on the shorty Deuce yet. I am going to put them on the Deuce when I run it in the Memorial Day parade this spring. It should be interesting, I have dual 9.00's in the back yet, so I have to do a hub-flip first. It should be interesting.
Pasaway
Las Vegas NV
Want to see pics when you do.
wehring
26
Angleton, TX
Mini monster
The reason I ask is because I am contemplating buying a set to put on the bobber for a fundraiser for the museum. "monster truck" rides at local events would go over well but the 395s do not look like a tonka toy. The 48x31s will look the part.
Justin Wehring
979 997 3112
