halftrack
- 10
- 38
- New Orleans, LA
Here is a question(s) for ya!
To Bruce, Chris, Army Ed, Bjorn and to whomever else can shed light. I am currently having my spare 6 CTA 8.3 rebuilt to be put in the M936A2 I got from Bruce. I originally thought that the either the head gasket was blown or the oil cooler was bad because I found anti-freeze in the oil filter. Well, after a little engine take-down I found that both the oil cooler and head gasket did not look damage or compromised. So I figured just bring the motor to the pros.
After I found a reputable competent machine shop to rebuild it, they called and told / showed me the problem. He said the motor itself had extremely low hours on it and looked like a new motor. However, the oil in water problem was due to liner pitting (looks like worm holes) and because the liners are “wet liners” the holes allowed coolant to seep into the crankcase.
Well, after talking to Bruce and doing a little research, I found out this damage was created by cavitations caused by high frequency vibration from when the motor is running (not going to get into great detail on the specifics). I know we have similar problems in flow control valves in pipes so it was not totally new to me. After further investigation, I found that this is easily preventable just by using certain anti-freezes or having a filter setup up that treats the coolant in which I noticed on most newer diesel trucks.
My questions are as follows:
Why does the military not have a filter setup for the coolant on the 939’s (I thought about adding one on my M936A2 before this even happened)?
If I where to add one, what lines do I need to tap into to ensure proper filtration (heater lines maybe)?
Any recommend particular brand of filter and or anti-freeze (fleet guard, etc…)?
Of course I attached a crappy picture along with some background info.
I would appreciate if anyone can enlighten me on the subject?
